Denon 2805
Discussion in 'AV Receivers & Amplifiers' started by SOUNDSTYLE, Sep 16, 2005.
Tags:
  1. SOUNDSTYLE
    SOUNDSTYLE
    Oct 4, 2002
    1,290
    +57
    I was thinking of getting the Denon 2106, but have decided to go for the 2805 instead, due to it having 'room eq', but is a new model taking over from it soon?
    If there is, then I might aswell wait, and get the 2805 cheaper.
    I have now come across the Yamaha DSP-AX757SE which seems to have as much as the Denon, but costs quite a bit less.
    Does anyone know if the Yamaha is to be upgraded any time soon, as If it is I could get it cheaper, If I wait.
    Decisions, decisions
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,465
    United Kingdom
    +1,941
    There's been no news of a replacement for the 2805 as yet so it's still a current model.
  3. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +6
  4. Pinoy
    Pinoy
    I am thinking of buying Denon 2805 or Denon 2106 as well . . . but is that the only difference between the two ? Will that make a big difference ?
    This could be a stupid question what does Auto Room EQ means ?
  5. dbeamish
    dbeamish
    Oct 26, 2003
    387
    Berkshire, UK
    +8
    I don't think the 2106 upscales svideo to component either (does int he states - not in Europe though)
