denon 2805
Discussion in 'AV Receivers & Amplifiers' started by cboy, Mar 23, 2005.
Tags:
  1. cboy
    cboy
    Dec 29, 2004
    559
    +4
    ive been looking on buying one of these beautys but i cant for the life of me see where the coaxil connection for the sub goes? any1 tell me pls?
    i can see 2 sub connections but there in the channel inputs on my yammy it had a dedicated port for the sub
    i know it might be a bit of a dumb question but some1 put my mind at rest pls..:)
  2. pinoslav
    pinoslav
    Feb 7, 2005
    Zilina
    the connector you are looking for is in the pre-out group of connector, betwenn antenna connector and the serial port.
    peter
  3. cboy
    cboy
    Dec 29, 2004
    559
    +4
    thanx for the reply m8
