Denon 2805
Discussion in 'AV Receivers & Amplifiers' started by Hyp3rion, Dec 13, 2004.
Tags:
  1. Hyp3rion
    Hyp3rion
    Oct 11, 2004
    38
    9
    Does the component output on the Denon 2805 output in progressive scan? If so is it dependent on the input being progressive or if i plug in a non progresive dvd player will it upconvert it to progressive?
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,370
    United Kingdom
    +1,733
    It will pass through a Progressive Signal. It can't de-interlace an Interlaced signal though.
  3. [Slip]
    [Slip]
    Jan 28, 2004
    190
    +4
    I am looking at this amp for that reason, is it correct that I can connect my projector via component to the 2805 and then connect all my other AV equipment via any other video input style and it will upscale it to component?
    Best price I can see for this is £519 currently, does look like an amazing amp!
    Anyone any experience with the auto setup function?
  4. MagicBoy
    MagicBoy
    Sep 19, 2003
    308
    +21
    It won't "upscale" the video from composite and s-video - just output what it receives via the component connections. The usual rule of hi-fi applies - crap in = crap out.
  5. S H A D O
    S H A D O
    Mar 16, 2001
    10,370
    United Kingdom
    +1,733
    The 2805 does have Video Upconversion from Composite and S-Video ;). Just bear in mind you won't gain quality as such, as it just converts the signal format.
  6. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,737
    71
    Land of the Living, Essex
    +35
    how about the downconversion to S-video? If I send a Progressive image via Component can it output that through s-video?
  7. patr1ck
    patr1ck
    Jun 29, 2002
    253
    Manchester
    +26
    The only downconversion it will do is S-Video to composite.
    Pat
  8. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    slightly off-topic does anyone know whether the 2805 can drive A+B main speakers simultaneouly provided that only 5.1 is used in the main room?
