Denon 2805 - Zone 2
Discussion in 'AV Receivers & Amplifiers' started by rdmcdivit, Aug 30, 2005.
Tags:
  1. rdmcdivit
    rdmcdivit
    Aug 24, 2005
    2
    I'm a new member but couldn't find any old threads on this subject.
    How do you configure Zone 2 on the 2805 to output to speakers?
    I have the Polk Audio Atrium 45s.
    I understand you can't output a digital signal but the manual is not clear at all on what settings are required eg: to send the tuner to zone 2.
    Any help on exact setup procedure would be appreciated.
    :confused:
  2. rdmcdivit
    rdmcdivit
    Aug 24, 2005
    2
    I was able to find a setup guide for the 3805.
    Menu selections for 2805 appear to be the same except you have 3 zones with the 3805.
    Here's the link if anyone needs the info.
    http://www.avsforum.com/avs-vb/archive/index.php/t-412318.html
    The key to it all, as stated in the other forum, is that you can only change the volume for zone 2 with the remote.
    This is not in the manual.
    :lesson:
  3. spl23
    spl23
    Jan 9, 2004
    2,670
    103
    +382
    1. Set the surround back / zone 2 power amp assign in the main setup menu to "zone 2".
    2. Connect your zone 2 speakers to the surround back / zone 2 speaker outputs.
    3. Press "zone 2 power on" on the remote.
    4. Press the "zone 2" source button on the remote.
    5. Press the source select button on the remote for the source you want to listen to in zone 2.
    6. Use the volume buttons on the remote to adjust zone 2 volume.
