Denon 2805 remote problems - help please!
Discussion in 'AV Receivers & Amplifiers' started by Unlight, Jan 2, 2005.
Tags:
  1. Unlight
    Unlight
    Jan 6, 2003
    1,438
    38
    Belfast
    +9
    Hey guys,
    For some reason today, my 2805 remote isnt working. For some reason, no matter what I press, the "learned" and "cd" icons light up together.
    Any info on what the problem may be, or how I could reset it?
    Thanks in advance!
  2. mjirvine
    mjirvine
    IIRC it tells you how to reset it in the manual.
    have you tried pressing the learn button at the bottom. mine got frozen once. I just unplugged the batteries for a few secs and replaced them and it worked again.
    if this doesn't work try leaving the batteries out for an hour or so. you will lose your memories I presume but it should work.
    good luck
    MJI
  3. Unlight
    Unlight
    Jan 6, 2003
    1,438
    38
    Belfast
    +9
    Hey there, I've had a look in the manual and it does indeed tell you how to reset - unfortuately I'm getting no flashing of buttons whenever I press the USE/LEARN button :(
    I guess something must be frozen somewhere? I've taken out the batteries and will follow your advice and leave them out for about an hour or so - hopefully this should reset it back to default, which I am happy enough with!
    Could it be anything else?
  4. Unlight
    Unlight
    Jan 6, 2003
    1,438
    38
    Belfast
    +9
    Problem solved - just popped the batteries back in and everything is working perfectly :)
  5. cdb
    cdb
    Mar 1, 2003
    456
    28
    +46
    Is this an indication of low batteries? Mine has intermittantly done if for a couple of months now:confused:
