Denon 2805 query
Discussion in 'AV Receivers & Amplifiers' started by pcavelle, Aug 20, 2004.
Tags:
  1. pcavelle
    pcavelle
    Jan 23, 2001
    985
    London
    +16
    Default surround format is always DTS Neo 6, regardless of whether the DVD has DTS on it or not.
    Is this correct?
    Paul
  2. Arcangel
    Arcangel
    Is your DVD player set to output a Bitstream signal? Also make sure the amp is set to AUTO.
