Denon 2805 prob - no power!
Discussion in 'AV Receivers & Amplifiers' started by First-Timer, Jun 24, 2005.
Tags:
  1. First-Timer
    First-Timer
    I was watching some TV as usual, switched off the amp to standby to go and have dinner, came back and the standby light is off and it will not switch on.
    Is this something fuse related? I was concerned that the plug said it required a 10A or 13A fuse and there was a 5A fuse fitted. I changed to a 13A fuse and it made no difference.
    Pls help as no TV at the moment!
  2. Jase
    Jase
    Mar 16, 2001
    9,412
    South Coast
    +858
    Strange. It could be an internal fuse that's gone. If the unit is completely dead and won't power up then you'll need to get it back to your dealer or Denon.
