Denon 2805 or 3805?
Discussion in 'AV Receivers & Amplifiers' started by sean in singers, Sep 4, 2004.
Tags:
  1. sean in singers
    sean in singers
    Sep 4, 2004
    Have just purchased a Pioneer 434, now need to buy my components. I am living in Singapore at the moment, so things are pretty cheap (3805 is $1K, about 340 pounds). So budget isn't too much of a consideration, although I don't really know too much about setting up a system.
    I plan on buying either the Pioneer 868 or Denon 3910 DVD (both are priced at $1500, or 500 pounds). It will be about 50/50 for music and DVD's. I plan on matching with AE Evo 3'b speakers.
    Question: I've got the cash for the 3805, but will I really notice the difference over a 2805 (and save myself a few bucks?) Any other options I should consider?
    Cheers Sean
  2. Daneel
    Daneel
    Dec 5, 2002
    2,833
    68
    London
    +8
    How much is the AX5i over there? It would be a great match to the 868.
  3. sean in singers
    sean in singers
    Sep 4, 2004
    They want $1800 for the AX5i; about 600 pounds. I looked at the specs, and I like the fact it has USB input for PC's; I plan on also building a media server, so probably a good plus.
    Cheers Sean
  4. h22x
    h22x
    Hi Sean,
    I'm from Singapore too, and was just wondering where I can get the 3805 for $1000? Thank you.
    Joey
