denon 2803 zone 2 speakers help
Discussion in 'AV Receivers & Amplifiers' started by ljake, Aug 2, 2005.
Tags:
  1. ljake
    ljake
    I have wired up 2 speakers as "Zone2", I can hear the Tuner through these speakers but cannot work out how to play the DVD or Sky signal into Zone 2. Anybody got any suggestions? :lease:
  2. Jase
    Jase
    Mar 16, 2001
    9,468
    South Coast
    +892
    Only an Analog signal source is output to Zone 2. You'll need to connect the DVD and Sky box (I assume it's SKY+) via a pair of analog phono cables as well.
  3. ljake
    ljake
    Much appreciated, plugging in analogue connections has done the trick. Its a bit of a pain as I have digital connection from the DVD, Sky box and PC. :)
  4. dood
    dood
    Aug 4, 2000
    943
    28
    Hobart
    +38
    Not a pain at all, you should have both analogue and digital connections simultaneously. When watching in zone 1 select digital input and it should remember this each time you select that source. When in zone 2 it's a simple matter of pressing the analogue button if necessary. If you use a remote like the pronto, you're really sorted. I have a page for "multiroom" which automatically selects analogue for any source in zone 2. The macros for use in zone 1 automatically take you back to digital input. This way I'm not even aware that different inputs are being selected.
