Denon 2803 or 3805?
Discussion in 'AV Receivers & Amplifiers' started by Colin Parker, Oct 13, 2004.
Tags:
  1. Colin Parker
    Colin Parker
    Is the 2803 enough to drive B&W 700's?
  2. bugsterbuns
    bugsterbuns
    Apr 24, 2004
    170
    yes yes and yes again
  3. TheeNoMaD
    TheeNoMaD
    Can you still get the 2803 from anywhere?
  4. bugsterbuns
    bugsterbuns
    Apr 24, 2004
    170
    yep try usual places sevenoaks or superfi still around though, if you can get a 3803 it would be a better choice though
  5. Colin Parker
    Colin Parker
    Why 3803 and not 5 mate?
  6. bugsterbuns
    bugsterbuns
    Apr 24, 2004
    170
    well unless you need all the extras the 3805 offers then fine, if not grab the 3803 at a bargain. it is still an awesome receiver
