Denon 2802 - Progressive/interlaced component
Discussion in 'AV Receivers & Amplifiers' started by naturally, Jul 7, 2002.
Tags:
  1. naturally
    naturally
    I am a happy owner of a 2802. I want to connect 2 DVD players to the Denon. One will provide a progressive NTSC signal and the other an intelaced PAL signal.
    Can I connect them both to my 2802 component in ? Will it just pass the signal to the video source (using component), or will the signal be modified ?
    Will it degrade the signal ?
    Another option which I do not like would be to buy another 8-meters component-RGB cable, but this will be expensive.
    Any ideas or pointers ?
  2. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    i have my tosh 510 connected throught the component in on my denon 2802 and the progressive mode on the tosh works fine through the amp with no picture degradation or processing, you should be amble to connect both players to the component in and switch them no problem
  3. naturally
    naturally
    Thanks.
    This is what I needed to know before buying the expensive cables.
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Why "expensive"? You can solder some yourself: a couple of meter SAT cable (75 Ohm) and RCA/phono connectors will do the trick, you can customize the length, too.
  5. naturally
    naturally
    I've tried this before, but it is difficult to get good quality cables here, and the projector I have takes a RGB 15 pin socket. So I need to make a component (3 RCA) to 1 15 pin. Too complex for me.
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Ok, point taken. ;)
  7. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    Naturally -
    This should work for the component signal but the signal from the region 2 player needs 4 cables - red, green, blue, plus sync on composite.
    If the Denon supports switching its composite video I/O in parallel with the RGB signal then IMO all will probably be well - if not I don't think it will work :-(
    HTH.
    John Dawson (Arcam)
  8. MikeK
    MikeK
    If I understand what naturally is trying to do, then yes, it should work.
    If I understand him correctly, he has two DVD players, both of which have component video outputs (one does NTSC progressive, the other PAL interlaced), and he wants to connect one to the TV/DBS component video IN connectors, the other to the DVD component video IN connectors, and then a single component video lead (well a set of 3 actually :) ) from the component video out connectors (MONITOR) to his projector.
    Providing the Denon can take the bandwidth on it's component inputs (and as it's designed to switch component video, I'd be surprised (and disappointed) if it couldn't) then I can't see a reason why it wouldn't work.
    Or am I missing something?
  9. naturally
    naturally
    YES.
    This exactly what I wanted to do.
    I got some cheep A/V cables (the stuff you get free with DVD players, VCR's .. etc) and tried the setup as detailed above with them. I worked fine (except for the signal degradation because of the cables). So I know now that it works. I placed an order for the cables.
    Thanks for all the help.
