Denon 2802.....no sound:(
Discussion in 'AV Receivers & Amplifiers' started by paulr, Aug 22, 2002.
Tags:
  1. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    Ok..........got the speakers wired in,amp is plugged in and turned on.........DVD is set as source........audio out from DVD to amp is wired up...........no sound????????????????
    What else is there????????
    thanks
    Paul..
  2. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,496
    Have you assigned the digital input? eg OPT1 - DVD. Also make sure the amp is set to AUTO.
  3. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,496
    Hang on a mo. Just spotted your post in General Hardware, if you haven´t got a digital cable of some sort (Optical or Coaxial) you won´t get 5.1 Audio. As a temporary measure use just one of your analogue cables as a Coaxial cable. Then assign the digital input COAX1 - DVD. Still make sure the amp is set to AUTO so that it detects the signal.
    Also check that the dvd player is set to output a Bitstream signal (Dolby/DTS).
  4. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    Thanks Jase......i had a feeling it was this....will get a digital cable today.....cheers.
  5. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    Jase....cheers mate,...just as you said.Got the optical cable and set the DVD for this as the output.Then set the Amp to auto,and 6.1 surround sound.
    Works a treat............
    Paul.
  6. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,496
    No problem:)
