Denon 2802 and KEF Eggs
Discussion in 'AV Receivers & Amplifiers' started by jag, May 20, 2002.
Tags:
  1. jag
    jag
    I demoed these at Sevenoaks in Nottingham. Awesome sound :cool:
  2. X3ELS
    X3ELS
    May 20, 2002
    1,151
    Surrey
    +108
    Very good combination but it can be improved by using a different subwoofer, something like the MJ Acoustics.
  3. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,627
    United Kingdom
    +2,233
    Did you buy them then??
  4. andyk
    andyk
    Dec 31, 2001
    769
    46
    North Yorkshire
    +166
    I have a 2802 and KEF eggs and am happy with the sound.
    The only cautionary note I would offer is to make sure they fit in with your decor. They are fairly obvious and they do make a bit of a statement. I have mine wall mounted and they stick out from the wall by quite a way.
  5. jag
    jag
    Haven't bought them yet. Just trying to get the best price at the moment, but I think it is the combo I want.
    Don't think they will be wall mounted though. Probably just get some stands.
  6. Rochdale
    Rochdale
    Mar 16, 2002
    359
    Leeds, UK
    Personally I don't like the look of the stands, they are just metal poles. So it looks like a speaker on a stick. Depends how much they cost of course, but I doubt the price will reflect the fact that it's just a silver metal rod with a foot on the bottom :)
    Did you compare the the eggs to any other speakers? I plan to compare them to the b&w vm1's and the mission fs2-av's when I get around to it :)
  7. jag
    jag
    The Missions are the only ones that I want to compare with. I didn't get a chance but I may still try this combo out. These would be a good but if they perform as well as the KEF's. I think I prefer the smaller KEF's in terms of how they would fit in the room.
    The helpful chap at Sevenoaks did think the Denon and KEF's were a great combo though.
  8. Guest
    I have the mission FS2-AV with the Denon 2802 and the combo sounds brilliant after a bit of run-in time.
  9. Rochdale
    Rochdale
    Mar 16, 2002
    359
    Leeds, UK
    I think the missions are smaller than the kefs, although I could be wrong. When talking to a dealer you need to remember that they will put the mission fs2-av system down because they make such a small margin on them :)
  10. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    Canterbury, Kent, UK
    +6
    got mine from ikon AVS for £620 dont let the amateur website put you off they are a great company with the best service, including after sales, I have encounted.
    I use mine with a 3802. If you're prepared to splash £1,000 on speakers & amp why not make it £1,100 and get a bloody good amp.
    2802 is good but the 3802 has that extra muscle and the ability for 6.1 / 7.1 sources such as DTS ES Discrete.
    I just got an extra Egg to make use of this benefit :D
