denon 2800
Discussion in 'Blu-ray & DVD Players & Recorders' started by G.M, Jan 14, 2002.
  1. G.M
    G.M
    I bought this player in December, unfortunately the fascia and
    drawer had cosmetic damage,so I returned the player.
    I had to wait 4 weeks for a replacement, this had cosmetic
    damage to the drawer. On closer inspection of the packaging,
    I realised it must be the mains plug that's causing the problem
    as it's packaged pins side next to the machine with no protective
    moulding, covering pins.
    My dealer has offered another machine or a replacement drawer,
    which is supposedly a straightforward clip on unit.
    Has anyone else with this machine experienced the same
    problem.
    thanks.
