denon 2800 problem need quick answer
Discussion in 'Blu-ray & DVD Players & Recorders' started by gizlaroc, Dec 18, 2002.
  1. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    hi all
    upgraded a friends 2800 recently and he has just called me to say that he is getting no video output, no composte or s-video for that matter.
    when i was round there i remember switching the progressive off in the menu and loosing the output on compnent but i am sure i switched to s-video to get back into the on screen menu and set it back to progressive.
    as I am trying to sort this over the phone it is a bit tricky so any info would be great.
    dont know whether this is anything to do with the upgrade or whether it has just died, we tested it after the upgrade with pal prog. and it worked fine, but this is the first time he has used it since powering it down completely.
    any ideas???????
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    thanks i will look into it
