Denon 2800 multi region software ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by joseph, Mar 10, 2003.
  1. joseph
    joseph
    Does anybody now what the multi region software is for the 2800, a friend said he has it on disc and it changes it to multi region. Does it work ,i thought you had to have them chipped to make Denons multi region ? What difference does the software chipping do ?
  2. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    A firmware upgrade is all that is required to enable Multi-Region and Pal-Progressive on Denon DVD-2800.
    A dealer will whizz it through or you can download it and make your own disc.
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    joseph,
    do a search, this has been asked very recently and download URL's were given for the firmware location...
    JJ
  4. allanrose
    allanrose
    Dec 14, 2002
    38
    but bear in mind this is not the latest software and firmware available - it's quite a bit out of date now
    you need to go to your dealer to get the latest and I believe that this is the Dec 2002 update (I'm sure someone will correct me if this is wrong)
    cheers
    AR
