S
siven
Does anyone know when the hdcd light will be turned on?
Is this only the case when you'll insert a hdcd disc or can this feauture be enabled through the setup menu of the dvd plkayer, like the progressive scan light/signal.
Also can they background "dull" standard denon picture be replaced by a capture from a source as dvd for instance?
thanks!
thanks!
