denon 2800/artifact
Discussion in 'Blu-ray & DVD Players & Recorders' started by Blu-rayx, Jan 3, 2002.
  1. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,217
    n/a
    +302
    has anyone had problems with artifacts on there denon 2800.
    e.g r2 enemy at the gates(dark scenes, looks like small gray squares).
    i had this problem with the ESS2550 /ESS2248 firmware,my old tosh 3109 did not have this problem.
    dvd
  2. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,217
    n/a
    +302
    come on guys help me out here!
    thanks
    dvd
  3. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    had my 2800 about 3-4 weeks, not noticed anything like this,
    apart from one disk that needed cleaning.
    do you have any other disks that the problem occurs on?
  4. Noman
    Noman
    Nope, picture is absolutely perfect, using component output and progressive scan on 100" screen.
  5. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,217
    n/a
    +302
    martinco,r2 seven chapter 13.
    what firmware are you using.
    using sqart rgb.
    dvd
  6. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    hi i have exactly the same problems!!!!!!!!
    i am using a sanyo plv30 on a six foot wide screen
    i notice it on very dark images it looks like the picture is shimmering i havent noticed on my tv through s video but have to admit havent really used the machine much since owning
    (tomb raider opening scenes when she is fighting robot)
    (and also noticed it on perfect storm)
    im using firmware 2248 i think pro scan etc via ixos av 172 component lead
    please help
    jason :(
  7. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    only got the R1 SE, not the R2 one (se I presume you mean).
    not sure... cant remember how you show it.. anyone?
    only had it since late Nov/ early Dec so it could be newer. tis multi region though.
  8. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    up
  9. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,217
    n/a
    +302
    hi jason,i phoned denon today an told them about the artifact problem with the 2800.
    denon said the player has a fault,so i'm going to take the player back this week.
    i'll keep you updated.
    dvd
  10. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    only got Seven SE R1 which showed no problems like you describe... got any more example discs since I dont have any of the 3 mentioned.
    my firmware shows as ESS2208... is this an older version or just the standard mr version? (I dont need the PAL progressive until I get a projector).
    Only "odd" problem I've had so far was:-
    some mpeg artifacts on 1 particular disc... still played on... turned out to be a very small thin thumbprint and affected only 1 chapter.
  11. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    hi dvd where did you buy your player???
    did you take it back to the shop you purchased it or somewhere else?
    i got mine online from germany !!!!!looks like i could have some problems then
    jason
  12. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,057
  13. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,217
    n/a
    +302
    hi jason,got mine from hi-way hi-fi edgware rd london.
    i took it back yesterday(9/1/02).
    dvd
  14. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    thanks gordon!!!
    dvd what is happening with your player are they sending it to denon?
    are they replacing it??
    jason
  15. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,217
    n/a
    +302
    jason,
    hi-way hi-fi have sent the player back too denon,but i don't know
    if they are going to repair or replace it.
    dvd
  16. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    hi dvd any news on your player??
    i sent denon an email about mine and they told me to return it to my dealer so it can be returned for testing!!!
    i sent them another email telling them i got it from germany and would it be possible to take it to a uk dealer under the european warranty,fingers crossed for the reply
    jason
  17. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,217
    n/a
    +302
    jason,
    i have to wait about two weeks:(
    i hope they can repair your 2800 in the uk, i'm about 99% sure they can :)
    dvd
  18. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,217
    n/a
    +302
    hi jason,
    denon replaced my 2800 works fine now :D
    dvd
  19. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    hi dvd
    what version firmware has your new machine got?
    did they give you a reason for the fault??
    this shows the problem when buying online i might have to send mine back to germany!!!!!!!!!major bummer
    glad you got yours changed dvd happy watching
    jason
  20. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    dvd, was this a complete swapout... did they say what the fault was?
  21. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,217
    n/a
    +302
    denon did not say what the problem was they just replaced it.
    dvd
  22. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    dvd are you based in london?if so are you in south london?
    do you fancy hooking your player up to my projector so we can compare them side by side if so drop me a line and we'll arange a day and time
    thanks
    jason
  23. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    can you beleive this i wondered why denon had stopped replying to my emails, and now i found out it was because i told them i bought it from germany !! it would of been nice if they had the decency to tell me but no i had to find out for myself!!
    look at this i still cant beleive it so much for europe!!!!!!
    We are sorry to say that, as we are only responsible for the UK and Irish markets, we are not able to respond to enquiries from other territories. Please relate to the list below for the contact details of your local Denon distributor
    jason
    :mad: :mad:
  24. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    I've been reading this thread with some interest as I bought my 2800 from Germany too. (as an aside I actually don't think under single market legislation Denon UK can just wash their hands of service commitments like this).
    I see artifacts on some disks too on very dark scenes, but on the whole I believe this is down to problems with the encoding of some disks. We have to remember that DVDs fit so much onto each disk by compression of the image and this inevitably leads to artifacts.
    I am intrigued that Denon have replaced one player as 'faulty' and I would love to know if I've been kidding myself that the player was only showing up MPEG artifacts when indeed it was faulty.
    A side by side showing with the 'fixed' player would definitely show this off, but failing this it might take one of us sending our player back to Germany to resolve this.
    Regards,
    Ian
  25. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,217
    n/a
    +302
    hi ian,
    i e-mailed jason yesterday saying i still have the problem,but it's better than the last one i had.
    i've still got my old tosh 3109 and when i play seven and enemy at the gates i don't see any artifacts at all,so the player must be faulty.
    can you please tell me what discs you can see the artifacts.
    thanks
    dvd
  26. jason t
    jason t
    Mar 4, 2001
    1,708
    48
    kent
    +38
    this is a joke my old pioneer 606 never had any problems like this and it was a first generation player i just cant beleive that i might send my player back to germany with a cost to my own pocket then i might receive another faulty unit!!!
    i think i would like to wash my hands with this player,and buy something reliable!!
    what i want to know is how it got so many good reviews for picture quality,dont this people testing the equipment check for things like this ??or are they just lucky that the test machines worked correctly (something i doubt)
    jason
  27. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    I'd be interested in what discs you see the problems in,
    so we can all do some comparisions with any different firmware levels (or chipset revisions if there is any).
    a list of specific discs, region (2 preferably), time start/end for starters.
    also details of what you are viewing on (pj, tv), connection type (rgb, svideo, component) and any other important info (100hz, noise reduction, etc).
    I've seen no complete glitches, but an odd "flash"/jump that was unreproduceable... maybe the 4mb buffer hid it the second time?
    think I'm on old firmware (ESS2208?)... I know there's the website with pal prog download.. are the other standard multi-region or region 2 versions available as well?
  28. ian_guinan
    ian_guinan
    Apr 14, 2001
    1,164
    38
    Australia
    +18
    Try this one for starters;
    From 40 to 50 seconds (setup AB Repeat) into The Matrix (r2).
    It is a monitor screen with a flashing green cursor on the upper left.
    On RGB, Standard setting for Display. On my player the supposedly dark screen breaks up into a pattern of geometric grey patches. I would have thought this is quite a torture test for many DVD players and some would have the same problem.
    My Realmagic DVD card and Wind DVD play this with a smooth black screen and from what I recall my Pioneer 717 could manage this without artifacts.
    This is such a common disk it should be one many users could try on their machines.
    I have found similar problems (from memory) on;
    a) Contact r4 PAL (may be the same for UK disk). Have a look at the night sky when Jodie Foster is descending to the beach after she has gone through the wormhole.
    b) The original (awful) pressing of 2001 has many scenes that fade to black. These posterise and break up into dark grey patches again.
    c) Just watched Cpt. Corelli. In the scene where she meets her fiance who has returned from Albania. A dark interior scene with blocking of the background.
    I'm running ESS2248, which was quite an improvement on ESS2208, and no different from 5248 in terms of artifacts. S-video has always been worse than RGB, though I haven't tried my player on component. Those I know who use their player this way have found no problems.
    I do find that it depends very much on the disk concerned.
    Regards,
    Ian Guinan
  29. elaysian
    elaysian
    I have had my 2800 for about 7 months now and I can honestly say that I have not experienced any of the issues you are describing.
    Have you checked you black level settings? If they are too high you will see blocks in large areas of black,this is due to digital compression/decompression.
  30. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    thanks Ian... I'll have a look when I get a chance...
    only have Contact (r2) of those discs, my Matrix is R1 but I'll have a look at it just out of interest.
    mention other region discs if you want, just said R2 preferably since I thought it would be easier if/ when someone talks to Denon or a shop.
    I've also still got my faithful old Pioneer 717 to try the discs with.
    where can I download the latest multi-region firmware then?
    currently going via RGB Scart, so dont need pal progressive... assuming they are different.
