Denon 2307 Eq Settings
Discussion in 'AV Receivers & Amplifiers' started by vivek225, Apr 24, 2007.
Tags:
  1. vivek225
    vivek225
    Hello All,
    I've bought a 2307 as my first surround amp. It is MASSIVE. I am waiting for delivery of my new 5.1 speakers, but in the mean time have my old stereo speakers connected to the B outputs. I played with the auto setup with these speakers.
    Q: Are the eq settings linked tied inputs/all only or are there separate settings for Speakers A and B?
    Vivek
  2. Jase
    Jase
    Mar 16, 2001
    10,934
    United Kingdom
    +3,249
    The actual EQ results it obtains are global but you can assign different EQ modes to different surround modes. e.g Flat for Stereo, Front for Dolby PLIIx. Up to you what mode you choose and if you want EQ on or not.
    You couldn't run it twice and apply one set of results to Speaker A and another to Speaker B for example.
  3. vivek225
    vivek225
    Thanks Jase,
    This may be an issue when using sat/sub on A for movies and a pair of floorstanders on B for music. Will need to think about it a bit more and try to delve deeper into the manual.
    Vivek
