DENON 2200 DVD problem reading discs
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ohboy, Nov 2, 2004.
  1. Ohboy
    Ohboy
    I have the Denon 2200 excellent P.Q. on component, however there seems to be a problem reading some copied dvd's. even tho' when I play the same dvd's through the Marantz dv4300, there is no problem at all.
    Has anyone else foud this with their Denon 2200.
    cheers
  2. HMHB
    HMHB
    Nov 11, 2001
    27,188
    Nottinghamshire
    +6,125
    I sure I've seen someone else with this problem but on one of the newer Denon DVD players. Try a search for "Denon DVD-R" and you should find something
  3. Ohboy
    Ohboy
    Thank you very much for your reply JohnG
    It was agreat help, I found quite a few threads on the Denon and problems with dvd-r problems.
    cheers
