Denon 2200: Any problems?
Discussion in 'Blu-ray & DVD Players & Recorders' started by AgentCool, Oct 17, 2004.
  1. AgentCool
    AgentCool
    Aug 5, 2004
    2,653
    Yorkshire
    +184
    I am thinking of buying a Denon 2200 to replace my Pioneer DV-575 which is giving me grief. Has anyone had any problems with this player regarding the following:
    1) Horizontal banding through RGB Scart on certain TVs as with the Pioneer?
    2) Inexplicable freezing and jumping when playing certain discs?
    3) Any other problems?
    Any info would be helpful. Thanks.
  2. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    Hi, heres my experance with my 2200 hope it helps you ;)
    1) Not had any on my Panasonic whilst i was running through RGB, i now use component and theres not a great deal of picture difference (when using a good quality scart cable) between the two
    2) No (only layer change problem on a bad copy of spiderman new copy no problem)
    3) Some units can have a sticky power button but no big problem though
  3. innercry
    innercry
    May 10, 2004
    67
    Midlands
    There is potentially a problem on the 2200 with certain DTS discs freezing at seemless branching points. I have the 2900 and know that this applies to the 2200. The discs I know it affected were Alien (Directors Cut) and Alien Resurrection, although I have heard there are others. The good news is, is that this is easily solved with a firmware update, which can be obtained via the thread 'Denon 2900 problem with Alien R1 DTS'.
    Hope this is helpful.
    Regards Mike
  4. daveb975
    daveb975
    Oct 25, 2002
    4,330
    103
    London
    +368
    I have only recently got my 2200, but have watched a few discs on it.
    Great picture via component into my plasma, sound is good too, although have not tried it for CD playback yet. It has not frozen on any of the discs that I have tried, and no layer change pauses.
    Build quality seems generally very good, although mine does have the slight problem with the power button mentioned above. I did not want to send it back for replacement as it is a minor problem, and the player is perfect in all other ways.
  5. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Had my 2200 for 3 months now. Stunning PQ via a Mark Grant component cable into my plasma. The only issues i've had:-
    Sticky power button as already mentioned
    Can vibrate quite vigorously if discs are slightly out of balance
  6. Stinky985
    Stinky985
    Jun 12, 2002
    675
    Nr Bath
    +6
    "Can vibrate quite vigorously if discs are slightly out of balance"
    Sorry i may be missing something but what do you mean?! I am expecting delivery tomorrow of my new 2200 and if it something to look for i'll look for it! And for that matter anything else to look out for (except the button - got that!)
  7. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    I've noticed that on some DVDs the player itself will vibrate. It makes no difference to playback and when I phoned Denon technical support they explained to me that the reason for the vibration would be because the disc itself is slightly unbalanced.
  8. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    In other words warped all i do if i get one like that (which is very rare that i have) all i do is to gently bend it back works for me :)
  9. Stinky985
    Stinky985
    Jun 12, 2002
    675
    Nr Bath
    +6
    I understand 'warped'!! Thank god for growing up with vinyl!! Thats great, cheers!! Look forward to putting it through its paces tomorrow!
  10. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    Let us know how you go on and what you think to the 2200 :)
  11. Phaedrus
    Phaedrus
    Hello,
    I have the 2200 as well. But...it has trouble loading or playing portions of some dvds...here are some:
    The fullscreen option on "Top Gun"...plays the widescreen option just fine, but not the fullscreen option.
    I have 2disc set of "First Blood"...it won't play the fullscreen disc of the two.
    And...the player doesn't seem to like to widescreen option in "Bug's Life" either.
    Anyone else experience this? Is it perhaps the firmware issue? Boy, I hope it's that simple.
    Phaedrus (Ontario, Canada)
