:: Denon 2105 not allowing back speakers ::
Discussion in 'AV Receivers & Amplifiers' started by Tob3z, Apr 18, 2005.
Tags:
  1. Tob3z
    Tob3z
    Jan 17, 2005
    194
    19
    Newquay, Cornwall
    Hi.
    I just got a new (first) setup and I managed to find some old cable in the garage.
    I have a problem though.
    I connected my 2 front speakers on friday and they are working fine.
    I have now connected the 2 rear speakers and in autosetup it gives me a error:
    SL/R :NONE
    Now I still have to buy some decent cable and connect all my speakers up.
    I still have to connect a sub and the center speaker.
    But the amp will only let me select the 2 rear speakers if I tell it I have surround speakers.... which I dont have and dont plan to get.
    I cant find anything in the manual about this.
    Has anyone got any ideas?
    Im hoping this amp works fine on 5.1 because I know its a 7.1 ... but it should ... right?
    Thanks for your time
    Toby
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    try the other rear speaker connections on amp, there are two sets i believe. I ahve a denon 3805 and remember I put it in wrong one first.
  3. Tob3z
    Tob3z
    Jan 17, 2005
    194
    19
    Newquay, Cornwall
    there are surround back (which is what they are in) and there is surround. Should I try surround?
  4. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    Yes. Use the SURROUND option. Not the SURROUND BACK (This should be your 6th and 7th channels)
  5. Tob3z
    Tob3z
    Jan 17, 2005
    194
    19
    Newquay, Cornwall
    nice one thanks
    :D :D :D :D
