denon 201 or seperates
Discussion in 'Hi-Fi Stereo Systems & Separates' started by needaplasma, Aug 18, 2004.
  1. needaplasma
    needaplasma
    hi there,
    i have been looking at a denon 201 with speakers, but have read for the money i can get a better sound with seperates.
    given a budget of 600-700 uk pounds (including speakers) what would people recommend?
    although looks are important my main objective is to get the best sounding equipment for my budget.
    many thanks
  2. lankor
    lankor
    Jul 13, 2004
    75
    i have a denon 201 in perfect condition selling for £280 only.
    can throw in a set of AE evo1 for £100
  3. andymc
    andymc
    Sep 18, 2003
    266
    Bedford
    +15
    You will do much better with seperates. Buy a copy of What Hi Fi or something like that and it will give you a suggested budget system. I think the current top budget is the Cambridge Azur 540 and 640 Amp and Cd player with speakers... hang on.. I will just check if I can - look at this link http://www.richersounds.co.uk/index.php?f=hifisystem.htm and that is a good starting point. I know the Azur is currently What Hi Fi's choice at this end but not sure which speakers they recommend. The most important thing for you to do is to take YOUR Cd's to the shop and listen to them on various things.... Decide what you think sounds good... everyones taste is different... let us know what you go for
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    Is that a rhetorical question?
  5. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    Marantz CD5400 + Marantz PM7200 + Kef Q1 + Atacama Nexus 6 Stands = £680
  6. nsherin
    nsherin
    May 14, 2003
    620
    Portsmouth, UK
    +23
    I'd also consider NAD kit - the C521BEE CD player and C320BEE amp are an excellent pair of components.
