Denon 1920 -> Yam 757
M
Madstadblues
Hoping you can help. having just done a technology refresh and I am having some teething problems. I have my 1920 hooked up to a Pioneer 436 XDE via HDMI - lovely. I have also hooked (via digital Coax) the 1920 to the Yam 757 DVD dig coax socket to power my audica speakers. Unfortunately I cannot get any sound. should I also connect the video component out of the 1920 to the 757 ?
I was planning to watch the 436 on mute (image via HDMI) and listen through the Yam linked by dig coax.
Thanks for your time.
MSB
IS there anything plugged into the optical input for DVD as well...the optical input takes priority.
M
Madstadblues
hmm good point I have plugged my sky + into an optical port in the Yam I couldn't say for definite which socket.
MSB
I
IanMerseyside
I have exactly the same system as you. Glad you got it sorted :thumbsup:
qypevj
I have the same DVD / Amp combo too and am v.happy with them - with the volume turned up of course....!
Similar threads
