Denon 1920 worth the upgrade ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by travid, Oct 18, 2005.
  1. travid
    travid
    Oct 18, 2005
    5,045
    Pentre bach yn Sir Gar
    +646
    New, so please be gentle.
    Panasonic 32pd50 (with prog scan), Denon 1804, missiom m cube.
    I currently own a Pioneer 656a dvd.Component outputs but no prog scan.
    No need for hdmi output yet.... However will I benefit from the Denon ie by using its progessive capabilities ?
    Thank you
  2. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    The review of the 1910 suggested that component was very good but not better than the Pio 575 if I recall.
    I would suggest that the 1920 would be about the same.
    I suppose you could argue that you'd gain SACD in one box and it would be useful for that as well as DIVX.
    But on component alone? I wouldn't bother.
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    Agree with above, I doubt whether you'll see much tangible benefit...PJ
  4. travid
    travid
    Oct 18, 2005
    5,045
    +646
    Thank you, very friendly and knowledgeable advice.
    Another technical question. Does the panasonic convert the signal from my non porg scan player into progressive scan, as well as a dedicated source eg Tosh sd350e ?
    Ta
