denon 1920 sacd problems
lordnoize
Hi I have some CDs that have a stereo SACD layer and a surround layer.
My denon is hooked via the 2 red&white audio outputs to the red&white on my viewpia/clear dragon
the SACD layers don't play and I'm not sure why. when I set the audio output to HDMI I can hear normal CDs and dvds
when I set output to analog I get no sound no matter what I'm watching.
I don't have a seperate amp for audio but I would still like to hear what an SACD sounds like through tv speakers!!
logiclee
The SACD analogue output probably uses the 5.1 external outputs not the stereo outputs.
Lee
Knyght_byte
it does indeed, on my 3910 anyhow, i would imagine thats uniform....
if you buy DVD-A you might find those will transmit over the HDMI, not sure tho on that model.....
mjcairney
Lee
Score out the "probably" and substitute "definitely".
Cheers,
Martin.
Trending threads
