Hyp3rion
I am currently using my xbox 360 as a dvd player and i'm just about fed up with the picture enough to spend some cash on a dedicated player.
My current setup is Sharp 37" GA4e, Denon 2805 which i use for component video switching, and MS Genies.
I was going to buy a Denon 1920 to match my kit and becuase of all the reviews but i was also considering some higher end kit that could be had for not much more money second hand or ex dem.
One player i may be able to stretch to is the arcam dv88 or 89.
What other options could i consider.
I dont really need divx (provided by Media Center and my xbox 360)
I dont really need MP3 (as above)
I will be using component connection.
Thanks in advance
Thanks in advance
