Denon 1920 Multiregion Hack?
M
Mossyman
Hello all! :)
I've just bough a 1920 from Sevenoaks - good price ta :cool: but totally forgot about the multiregion bit and it's not! Is there a hack? Should be no problem taking it back as I know them well.
Thanks!
Mossyman :)
Miniholic
I
imagmo
You would have thought a dvd player as good as this would be multiregion
hillster
Mossyman said:
Hello all! :)
Thanks!
Mossyman :)
There is a firmware update that can be downloaded. Think it was posted here somewhere...
neilmcl
lordnoize said:
you can buy the player multiregion anyway
i wouldnt risk updating firmware
Considering the OP has already bought it this is now the only option open to him other than returning it and buying a multiregion one instead.
rooo
The MR versions you buy will have the same firmware update, just done by the store rather than the buyer.
And it really is very simple.
2
2integrate
I am trying to find multi region hacks for the DENON DVM-1815 and the DVM-1835 DVD changers, and have not had any luck.
Your help would be appreciated.
