Denon 1920 - lip Sync Problem
dextercat
Anyone had any lip sync problems with this player?, I hadn't until I watched a couple of DVD's yesterday and the sync was awful!.
Is there any solution?
Dextercat :(
B
bluecupra
Dextercat :(
Sometimes i also have lipsync problems with my DVD1920. What's causing this ? The player, the receiver or the screen (Hitachi 42PD7200). Would also like to know how to correct this. My receiver hasn't got an option to delay the sound
Jeffrey
Cable Monkey
Is this with Dolby Digital soundtracks, DTS and is it persistent or just there for a few moments partway through the film? Any sample discs?
dextercat
Dolby Digital, some scenes are ok others are awful, seems to get worse towards the end of the discs. Samples - Queer as Folk and Queer as Folk2.
Channel 4 specials.
Cable Monkey
Is it happening after the layer change? I have seen this on Denons before. It is fixable in firmware.
Repton
DVD movies, due to their length, are usually stored on two layers of a disk, a layer change is when your laser refocuses onto the next layer of a disk. In the old days you have to flip the disk over yourself half way through a movie.
dextercat
Oh yea, right it did hesitate a bit but I don't recall the lip sync being any worse after that. It certainly was worse towards the end of the film though.
So how do we get a firmware update?
C
cyclocommuter
Dextercat :(
The lipsync problem is most likely caused by the Faroudja DCDi the Denon uses. This has been an ongoing problem with DVD Players and older HDTV sets using Faroudja DCDis. I have read countless posts in other forums complaining about lipsync problems with OPPO DVD players which also uses Faroudja. The lipsync usually goes away when you stop or pause for a few seconds then resume playback again.
My older generation Samsung DLP (HLN5685W) had this problem and I had to return it...
dextercat
So is it best to return them or should we wait to see if there's a new version of firmware? My problems are on HDMI too.
B
bluecupra
I have watched two movies tonight (Cursed 2005 and Fever Pitch). Both looked absolutely fabulous on my Hitachi 42PD7200. The sound on both dvd's was 5.1. There was no sign of lip sync problems.
The next time i watch an DTS DVD i will pay extra attention to the lip sync
S
Spacedog
Also have a Denon 1920 running through [email protected] and have already tested a lot of movies and no sign of lipsync issues...
And let me say, even without DVE calibration (I'll only be doing it tonight) the PQ is just AWESOME on my Sony V32 !! Yesterday I re-watched "Pulp Fiction" which is a relatively "old" title and the quality of the image was absolutely stunning !!! Clean-clean-clean, detailed-detailed-detailed !!! Love that Inglewood fella ! :D
dextercat
So perhaps it's just my player then? The quality of picture is superb I agree and it was only the dvd's mentioned that had a problem - anyone else have theses and can test?
I am not using an AV receiver at present so there is no compensation involved.
CLH
I've had lipsync issues on some discs with my Denon 1910.
Awaiting my 1920 at the moment.
Eddy Boy
Is this between audio from your A/V amp and display? Have you tried running SCART to your screen and seeing if the audio is out of sync with the image?
dextercat
Eddy Boy
I am using a HDMI connection between the 1920 and a Toshiba 32wl56. I haven't got my speakers yet so I have not connected my av reciever up (Denon 1906). When I get the other stuff sorted I'll test it with oterh connections and I believe the 1906 has lip synch compensation ( don't how how this works or if)
lordnoize
ive had a few sync problems but i just press pause then unpause. often sorts it! check the settings to make sure you havent got the dialog playing fast
press mode when playing and its 3rd or 4th setting i think... meh its in the manual!
rooo
Had slight problems with Ghostbusters last night, but it was less than a minute.
Watched Pulp Fiction in DTS on Saturday though, and it was awful in places. Stopping and restarting didn't seem to do much. Sorted itself out in the end though.
Picture was absolutely gorgeous though.
jpk2112
I am having problems with some of the DVD's i've been watching on my Denon 1920. Some are ok but music dvd's are terrible. The sound is a split second ahead of the screen.......although that only seems to be through my surround sound system. Driving me a little crazy as i want to listen to the sound in full effect :eek:
Using HDMi cable from DVD to the TV i cant really tell any delays. Will try some other dvd's and see how that goes.
dextercat
Cheers guys,
The dealer that I got my 1920 from said it was wouldn't be the 1920 that caused the problem but my TV. What TV's/monitors do you guys have?
Detercat :thumbsup:
Repton
not experienced any problems so far with my Hitachi42PD7200
Latest News
What's new on Netflix (UK) for October 2022
  • By Ian Collen
  • Published
Starzplay streaming service rebrands as Lionsgate+
  • By Andy Bassett
  • Published
JVC adds Filmmaker Mode to latest D-ILA projector firmware
  • By Andy Bassett
  • Published
Bowers & Wilkins launches Px8 headphone
  • By Andy Bassett
  • Published
Sky set to launch its plug-and-play Sky Stream solution
  • By Ian Collen
  • Published
