Denon 1920 HDMI Switch problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by mng70, Mar 25, 2006.
  1. mng70
    mng70
    Jan 28, 2005
    36
    Hi guys, having recently upgraded to Telewest TVDrive it has become a necessity to purchase a HDMI switch to allow HDMI connectivity to both devices. I purchased a switch box http://www.tvcables.co.uk/cgi-bin/tvcables/hdmi-switch.html and it doesn't appear to work with the Denon. The TVDrive works fine but when I switch over to the Denon I see nothing. The HDMI light is lit at the front. Has anyone else had similar problems with HDMI switch boxes?
  2. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,300
    Have you tried powering the Denon unit up after the HDMI switch has been set to the relevant input?
    It's possible that some of the handshaking is going screwy.
    Steve
  3. mng70
    mng70
    Jan 28, 2005
    36
    Hi stevelup, yes I've tried every combination. I even re-flashed the 1920 to version 1.24 r0 again. The think is, it works okay when connected to the projector but doesn't work through the switch. the switch is supposed to be HDMI 1.1 compliant. Any other ideas?
  4. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,300
    No, sorry - I've not nothing else to add. All I can suggest is that you speak to the manufacturer of the switch?
    Steve
