S
sallyann
There are a few threads relating to Denon 1920 HDMI problems and I would like to try and collect some data in an effort to determine if there really is a problem. Just to clarify my problem. I connect the Denon 1920 HDMI output to my Viewpia TV's DVI input and there is no picture. The TV appears to see the signal briefly and then says there is no signal. This cycle is repeated every couple of seconds.
If you have a denon 1920 please answer the following: -
1. What is your TV make/model ?
2. Is your TV input HDMI or DVI?
3. Does your denon/TV combination work ok via HDMI ?
Thanks for your input.
