Denon 1920 HDMI - DVI
Discussion in 'Blu-ray & DVD Players & Recorders' started by nsd3, Oct 28, 2005.
  1. nsd3
    nsd3
    Jan 6, 2004
    19
    Newcastle
    I'd like to replace my current DVD player with the Denon DVD1920. I use a Sony VPL-HS10 LCD projector as the primary display source for my home cinema. The projector only has a DVI interface. If I connect the Denon DVD-1920 to the Sony VPL-HS10 projector via a suitable HDMI-DVI cable, will I actually get a picture? I'm concerned the lack of DHCP will cause the player to refuse the connection!
    Thanks in advance.
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    If your projector is not HDCP compliant, you will definately not get a picture for copy protected material. I don't know what the Denon will do for non copy protected discs - some use HDCP irrespective of the copy protect flag bit. Irrespective of the copy protect bit on the disc, you may get parts of the disc like trailers and the menu showing, but not the main feature.
    Probably not what you want to hear.
    -Ian
  3. mjcairney
    mjcairney
    Oct 26, 2003
    7,319
    2
    137
    Airdrie, Scotland
    +1,105
    Hi Ian,
    Are you sure about this?
    I thought that DVD protection was Macrovision and not HDCP.
    Interested to hear your answer.
    Cheers,
    Martin.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,618
    Rainham Essex
    +2,547
    Macrovision is the copy protection used on analogue outputs and HDCP is used on the digital connections.
    Mark.
  5. mjcairney
    mjcairney
    Oct 26, 2003
    7,319
    2
    137
    Airdrie, Scotland
    +1,105
    Yes, of course you're correct.
    Cheers,
    Martin.
  6. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    The copy protect flag triggers the copy protection mechanism in the player. It is up to the player what copy protection it uses. As Mark says, its normally macrovision for analogue and HDCP for digital. This is why discs made before HDCP was invented still trigger HDCP and unlicensed/hacked DVD players don't output HDCP/macrovision - they don't remove HDCP/macrovision, they just ignore the state of the copy protect flag and don't add HDCP/macrovision in the first place.
  7. mjcairney
    mjcairney
    Oct 26, 2003
    7,319
    2
    137
    Airdrie, Scotland
    +1,105
    Yes, I understand - thanks for that.
    Cheers,
    Martin.
  8. DaMacFunkin
    DaMacFunkin
    Oct 30, 2005
    658
    43
    +100
    You can get a converter box from www.keene.co.uk that will transfer HDMI to DVI-A or RGBHV (15 pin d-sub) and also emulates HDCP for non compliant panels.
  9. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    Both the 1920 & HS10 are HDCP compliant, you'll have no problems.
  10. nsd3
    nsd3
    Jan 6, 2004
    19
    Newcastle
    How did you deternine the HC10 is HDCP compliant? I looked through the projector manual and it isn't mentioned once.
  11. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    +3
    It's not mentioned in the manal, but rest assured it is HDCP compliant. I have a Denon 2910 (HDCP compliant) connected via DVI-D and if the HS10 was not HDCP compliant then there would be no picture as the handshake between them would fail. Denon players require that for DVI/HDMI output, the receiving device be HDCP complaint.
  12. nsd3
    nsd3
    Jan 6, 2004
    19
    Newcastle
    Thanks for that. I'll go ahead and sort out buying the player. Just one final question, how have you found the picture quality when using the DVI connection, any improvement, and what about the upscaling features on the player, and discernable difference?
  13. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    http://www.avforums.com/forums/showthread.php?t=258741
  14. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    +3
    Via DVI, one word STUNNING - crisp, clear, and life like. Just make sure you use AVIA or DVE to calibrate the HS10 for the DVI input from the 2910 - Normal Black (not Enhanced) with 0IRE, left everything else in the setup as from the factory, but I did play around a bit to see how everything affected PQ.
    Just make sure you are running firmware 6720-A or later, there is a MultiRegion version that I posted the link to over at videohelp.com
    http://www.videohelp.com/dvdhacks.php?dvdplayer=2910&hits=50&Search=Search
  15. Daddy k
    Daddy k
    Jul 19, 2004
    9,083
    coventry
    +1,351
    sorry to sort of hi jack this forum but its along these lines ;)
    im prob going to be getting this dvd player as my xmas gift upgrading from my dvd player as listed in my sig.
    now i have an lg rz 42 px11
    i would like to connect ideally via the dvi connection, does anyone know if these 2 will work well together using this connection?
