Quantcast
Denon 1920 - Blacker than black??
yellowpostit
Does anyone know if it does this?
Anyone that's got one and has a Star Wars DVD, run the THX tests in the languages section, and on the screen where the THX logo is used to test greyscale, you should see the dropshadow on the lettering if your player does BTB.
Cheers!
Timbo21
Strangely on my 3910 to my 7205 projector via HDMI it doesn't show the drop shadow. However, via component it does! And the black level appears to be better via HDMI ???
