Denon 1912 with Harmony 600
Discussion in 'AV Receivers & Amplifiers' started by zakerrman, Jan 9, 2012.
Tags:
  1. zakerrman
    zakerrman
    Jul 2, 2009
    19
    Does anyone know/have experience whether this remote works well with the Denon 1912?
    Many thanks
  2. davepuma
    davepuma
    Jun 24, 2004
    17,529
    +3,506
    Pretty much anything will work with Harmony remotes. If there are any non responsive commands in the database, you can just learn them from the original remote. I haven't come across any problems with the Harmony database for a long time and any issues are usually quickly resolved by the Logitech team.
  3. zakerrman
    zakerrman
    Jul 2, 2009
    19
    Thanks Dave. I suppose what I'm also asking: is scrolling through the various speaker output options from the Denon using the remote easy and intuitive. i.e. can you assign any button on the harmony to a certain action from the original Denon remote? Source select wouldn't be a problem, but I'm thinking about switching between stereo and surround etc.. I appreciate the harmony will not be as detailed as the original.
  4. PSM1
    PSM1
    Dec 20, 2008
    26,265
    +5,423
    Within the software you can assign any button to any command, so you can configure the remote exactly how you want it.
