denon 1910 to sharp 26ga4e via dvi help
Discussion in 'LCD & LED LCD TVs Forum' started by advice-needed, Mar 2, 2005.
Tags:
  1. advice-needed
    advice-needed
    got my lovely sharp 26ga4e
    got my lovely denon 1910
    got my new dvi to dvi cable today
    so why can'ti get the F~#@$%g thing to work!!!
    so far the best i have done is get a red tinged picture!
    bloody lost that now as well
    comeon guys your advice here pushed me towards this combo please help me to get it going!!
    i know it will be something simple but an idiots guide to setup would help
    cheers
  2. Alan D
    Alan D
    I can't comment on the Sharp, but I have the Denon going into a Philips via DVI. Have you tried all the options on the Denon's DVI button (on the front panel)? Page 15 of the Denon manual under DVi setup.
  3. advice-needed
    advice-needed
    got a picture now on 1080 but it is red
  4. Alan D
    Alan D
    How's the picture via Scart?
  5. advice-needed
    advice-needed
    fine last night
    been desperate to see the dvi connection the picture looks pretty cool just very red!
    just turned the denon off then on again and now lost the picture!! :lease: :lease: :lease:
  6. Alan D
    Alan D
    What make of DVI cable have you got? How long is it? and how much did it cost?
  7. advice-needed
    advice-needed
    it is a 1M £20.00 from IXOS
  8. advice-needed
    advice-needed
    i am sure it is a setup problem somewhere ut i have gone through the manuals and just can't figure it
  9. Alan D
    Alan D
    That should be fine. I'm kind of wondering where all the Sharp experts are tonight! Although it is unclear exactly what is causing the problem. Off the top of my head a "red picture" may be a component connection problem, but that shouldn't apply here.
  10. Alan D
    Alan D
    I've had a quick look at the Sharp manual online - it's not something odd like the PC input colour settings? Page 25 of the Sharp manual (maybe the red is cranked up!). I admit this is a stab in the dark, but in the absence of any Sharp buffs, worth checking the setting!
  11. Alan D
    Alan D
    Another thought, "signal type" page 37 of the Sharp manual. Is the DVI (Input 4) expecting the wrong input? - again worth checking this setting.
  12. advice-needed
    advice-needed
    tried the last 2 nowlost the picture and have a lovely shade of pink fuss and the message "out of range" popping up now and again
    very soon i am getting out mr portable and a dam vcr
  13. Alan D
    Alan D
    Out of range indicates the TV is receiving a signal it doesn't understand. Worth re-checking that the DVI input is set for the right source.
  14. advice-needed
    advice-needed
    cheers for your help alan but i am at a loss now
    i've tried everything i can think of in every combination just pink fuzz
    time to read a book by candle light i feal i am becoming a luddite
  15. LcdGuru
    LcdGuru
    The Sharp takes both digital and analog (VGA) inputs via the same physical connector. You can flip between two signal types by selecting 'PC Digital' or 'PC Analog' modes on the options/input select menu.
    If the picture looks red it could be a connection problem with the green signal - eg. due to a dodgey cable.
    Perhaps you could test your cable on a known good system - like your PC.
    Keep experimenting - my Sharp works fine with both DVI and VGA inputs :thumbsup:
    Good luck.
  16. advice-needed
    advice-needed
    thanks for all your adviceand guess what now sorted and well impressed
    the problem i hear you all ask??
    my new dvi cable had a blummin bent pin i did not notice god i feel a plum
  17. Alan D
    Alan D
    Hey! glad to hear you are sorted. Now, sit back and enjoy....
  18. advice-needed
    advice-needed
    donnie darko looks so good i want to cry!!!
    :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
