Denon 1910 to AE500 dvi-d
Discussion in 'Projectors, Screens & Video Processors' started by patt, Dec 3, 2004.
  1. patt
    patt
    Nov 18, 2004
    396
    huntingdon
    +10
    Hi i have connected my deon 1910 to my AE500 by dvi-d but no picture ,now denon dvi light is on set at 480 and pj on dvi in but no luck, if i run same lead from computer it is fine can some one help please
  2. patt
    patt
    Nov 18, 2004
    396
    huntingdon
    +10
    help me come on
  3. paulfoley
    paulfoley
    Sep 17, 2003
    3,549
    Hants
    +114
    I have this combination working well so no incompatabilities here.
    Reseat the cable, ensure progressive is enabled on player (in menu I think) press DVI until 720P is displayed, press PC on the Panny remote until DVI is displayed. HDCP handshake usually just takes a couple of seconds. If no picture then go into AE500 menu and change EDID from 1 to 2 or 2 to 1.
    If still not working then perhaps its just cable to blame ? What make / length is it ?
    Good luck.
    :thumbsup:
  4. patt
    patt
    Nov 18, 2004
    396
    huntingdon
    +10
    Hi thanks paulfoley this worked well thanks
  5. patt
    patt
    Nov 18, 2004
    396
    huntingdon
    +10
    o dvi-d is 10m got from ebay fo £20 and works well
  6. paulfoley
    paulfoley
    Sep 17, 2003
    3,549
    Hants
    +114
    Glad you got it working. What was it in the end ? My bets on the EDID setting?
    :smashin:
  7. patt
    patt
    Nov 18, 2004
    396
    huntingdon
    +10
    HI yes it was thanks
