Denon 1910 Questions ....
Discussion in 'Blu-ray & DVD Players & Recorders' started by Alan111S, Jan 13, 2005.
  1. Alan111S
    Alan111S
    Oct 28, 2004
    78
    Hi there
    Couple of quick questions re Denon 1910. Am planning to hook it up to a Philips 32PF9986 via DVI.
    1) Anybody got experience of whether the 1910 will play DVD+Rs. Or if the 2910/3910 plays them.
    2) Which DVI cable to go for?
    3) Is Peter Tyson the best place to get it from?
    Also, has anybody got strong views on whether the Panny s97 or Sammy HD945 are better players.
    Thanks in advance for any info/experience. :lease:
    Alan
  2. Aquila
    Aquila
    Oct 14, 2004
    69
    9
    Bruges - Belgium
    I'm interested in all those things as well... ;)
    And I'm also considering the Philips DVP900SA.
    All my previous Philips DVD players handle DVD+Rs very well.
  3. svrmarty
    svrmarty
    Dec 16, 2004
    13
    1) sure it will
    2) how about oehlbach ?
    3) goto your dealer and check it yourself :)
  4. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    1) I have to dissagree with svrmarty on point number 1.
    These denon players dont work with DVD + RW.
    They only work with DVD - Disks.
    2) I use a monster DVi-DVi cable and noticed a considerable improvement over a cheapo dvi cable.
    (just make sure your TV is HDCP compatible other wise the DVi link wont work with the DVD poayer. LCD monitors ment for PCs also wont work)
    3) cant help you there mate. I live in Japan and bought my 3910 here for 500 quid. (100.000 yen)
