Denon 1910 and blocking
Discussion in 'Blu-ray & DVD Players & Recorders' started by Such, Nov 10, 2004.
  1. Such
    Such
    Dec 27, 2003
    2,250
    63
    Greenhithe
    +118
    I connected my 3 week old 1910 to my tosh 51 wh36 over the weekend via component progressive. I did originally buy this player to go to my sanyo Z2 via the DVI, but wanted to keep 1 player rather than 2, ie one for pj and other for tv. I was intending to replace my toshiba 520 with the 1910.
    The picture quality on the 1910 is shockingly bad compared to my toshiba.
    The 'blocking' reminds me of a cheap freeview box. I have yet to see a picture so bad. There is also alot of 'dot crawl' on backgrounds.
    I have spoken to Denon and have tried the 'play/fwdskip/open' reset, but this is not resetting the player.
    The dealer is swapping the unit on Thursday.
    Has anyone got a unit that shows good picture quality as I am seriously considering a different player. I need one with DVI out, perhaps the samsung 945?
  2. Alan D
    Alan D
    I've had a 1910 for a few days and SO FAR haven't noticed any obvious picture problems via DVI apart from an offset (the picture is shifted to the right and slightly down - but I am chasing a firmware update to tackle this). Certainly it looks pretty good at 720p and 1080i.
  3. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    Sad to say the 1910 does suffer frm bad macroblocking which cannot be fixed.
    Some displays will make the MB look worse as well(such as panasonic plasmas)
    Most of the dvd players that have the same faroudja DCDI chip suffer the same.
  4. paulfoley
    paulfoley
    Sep 17, 2003
    3,569
    Hants
    +119
    Had mine about 3 weeks, never seen any freeview type blocking or dotcrawl in the picture ? I am using DVI @ 720p.
    You must have a bad unit ?
    :p
  5. Stellavision
    Stellavision
    Apr 7, 2003
    2,398
    Southsea, UK
    +102
    Yes, but Paul, you had your firmware recently upgraded didn't you?
  6. mojomanic
    mojomanic
    Had my 1910 5weeks and picture is excellent no probs at all. Using DVI to a 4805 pj, have tried 480p, 720p & 1080i difficult to tell which gives the best result. All good!!
  7. Such
    Such
    Dec 27, 2003
    2,250
    63
    Greenhithe
    +118
    Yes, it was upgraded via disc from dealer. I had used it only via dvi prior to the last weekend.
    Would this affect the picture thru component?
  8. paulfoley
    paulfoley
    Sep 17, 2003
    3,569
    Hants
    +119
    Hi mate, you're not too far away are you ?
    My firmware upgrade simply enabled M/R capability, I saw no differences other than that.
    Did you get yours from Phase 3 in London Road ?
    :thumbsup:
  9. Such
    Such
    Dec 27, 2003
    2,250
    63
    Greenhithe
    +118
    Got mine over the net from HiFix. They didn't mind swapping it for another unit, but if the new one is the same i'll seek a refund.
    I'm near the dartford tunnel.
  10. Stellavision
    Stellavision
    Apr 7, 2003
    2,398
    Southsea, UK
    +102
    I bought mine on the classifieds here, but have had a lot of email conversations with AV-Land at Northampton where the player originates from, so far with no success.
    I spoke to phase 3 at Southampton and they wanted £60 for the firmware upgrade which is ridiculous! All they have to do us put a disk in and press a couple of buttons.
    All I want is a disk with the 1.10 update on it so I can install it myself over the dodgy 1.09 which is on there at the minute.
  11. Such
    Such
    Dec 27, 2003
    2,250
    63
    Greenhithe
    +118
    Is this the MR upgrade that you are after?
  12. Stellavision
    Stellavision
    Apr 7, 2003
    2,398
    Southsea, UK
    +102
    My player is already multiregion, but I need the latest firmware update.
    I don't know if the 1.10 firmware I am after is just a mr update or a general software update. Hopefully both, as I obviously don'y want to stick a disk in and loose my mr faccility.
  13. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
  14. Such
    Such
    Dec 27, 2003
    2,250
    63
    Greenhithe
    +118
    Just took delivery of a new 1910 last week and watched harry potter 3 r1. The macroblocking is still there via component(P). Yet to check DVI, will try this pm! Does anyone know how to turn off the black level,- i've seen this mentioned on another forum and it seems that this may help?!
  15. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    You've probably seen it on avsforums. There is no option to amend black level on the PAL version of the 1910.
  16. Stellavision
    Stellavision
    Apr 7, 2003
    2,398
    Southsea, UK
    +102
    You can adjust the display brightness within the display settings though.
