denon 1907 vs sony dg710
Discussion in 'AV Receivers & Amplifiers' started by toothe, Jan 21, 2008.
Tags:
  1. toothe
    toothe
    Which of these is better?
    if the sony is ill defo get that, if it the denon then ill look around to find in black first lol. if not it'll be silver.
  2. toothe
    toothe
    well i've found them both within my price range in black. the sony has hdmi (which i dont need as my tv is dvi only and so inputs will go via optical) which is another reason the denon looks better more inputs and apparently better sound although when in richer sounds they said the sony has the best sound for the money (but this was 50 quid dearer at the time)
  3. toothe
    toothe
    anyone? dont wana waste money etc?
  4. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    You'll get more replies in the evening as most people have to work during the day on a Monday :)
    Leave it a few hours then see if anyone responds, but the two amps you are asking about are not the most popular around here so it may take a while.
  5. toothe
    toothe
    cheers, yeah am on quite a budget. looks like the denon one is a lot better but hear a lot of people saying sony are the bomb :p
  6. toothe
    toothe
    also looked at the 1508 denon as well. seems to be identical to the 1907 with hdmi. is this true. thanks
  7. toothe
    toothe
    it seems the 1508 doesnt upscale onto compnonent so thats out the question. i can only find the 1907 in silver as well which isnt a major issue just a preference. is the denon better than the sony?
  8. sp_harris
    sp_harris
    Feb 13, 2006
    582
    +60
    I would suggest going to a shop/dealer and listening to both amps together, then you can decide which is better.
