Denon 1907 + Canton Movie 120 MX setup
Discussion in 'AV Receivers & Amplifiers' started by krazyeone, Feb 2, 2009.
Tags:
  1. krazyeone
    krazyeone
    Jan 20, 2009
    2
    Hi all
    Could you please share you settings on this receiver for Canton Movie 120 MX speakers
    What about subwoofer, how did you set crossover and volume?
    I connect RCA cable on L Cinch socket but I am not shure that it's OK
    My room is 5.5 x 3.5 Meters
    Best regards
    Thank you in advance and I would appreciate some advice please
  2. krazyeone
    krazyeone
    Jan 20, 2009
    2
    I read another post about subwoofer input:
    'Which input do i plug the subwoofer lead into?'
    There are a range of inputs on the back of a Canton sub. for all aV requirements, you need the Red 'Low level' input marked up as 'R/Mono'. The Left low level input is not required unless using the L&R preouts on an amp.
    There are also high level inputs (speaker level) which can be used for stereo applications.
    Both high and low level inputs can be fed into the sub at anyone time. if the sub detects 2 signals, it will defer to the low level input.
    Still if you be king to share other settings on your receiver
    Thank you
