Denon 1906 - Wiring
Discussion in 'AV Receivers & Amplifiers' started by MIKEB17, Mar 13, 2006.
Tags:
  1. MIKEB17
    MIKEB17
    Jan 15, 2006
    957
    28
    +37
    Have I bought the wrong amp :( , I need to wire in 3 DD/DTS bits of kit, have got
    360 going into VCR component and then TOSLINK into AMP
    SKY+ going into TV Component and then TOSLINK into AMP
    DVD going into DVD component and then COAXIAL into AMP
    problem is the VCR component channel always goes straight into Stero mode and won't let me select digital, is amp only capable of two digital inputs?...if so do I need to retunr or is there cheap adapter I can get?
    Thanks in advance
  2. clockworks
    clockworks
    Dec 7, 2005
    3,573
    West Country
    +297
    I use all 4 digital inputs on my Denon 3802. I'm sure that your 1906 should allow the same.
    Have you assigned the digital inputs to the device inputs correctly? The digital inputs can be individually assigned to any of the device inputs, you may have got 2 of them working on the default settings.
    Have you tried swapping the sky and 360 toslink cables around, to make sure that the amp is actually receiving a good signal from both devices?
  3. MIKEB17
    MIKEB17
    Jan 15, 2006
    957
    28
    +37
    Will give it a go when I get home :) , this is my first major AV wiring job and it's highly likley I screwed up.
    Can you confirm for sure though that input 3(VCR) can take a digital connection, also is there a facility to rename inputs somehow?
  4. S_Bob
    S_Bob
    Dec 19, 2005
    143
    +15
    i have my xbox 360 on the VCR input and am using optical digital with no problems on my 1906. Use set up to assign that digital input to VCR.
    yes, you can rename the inputs its also in setup.
    edit: spelling
  5. MIKEB17
    MIKEB17
    Jan 15, 2006
    957
    28
    +37
    Cheers, will check it out at home, normally i'm not so lazy with manuals but bought alot of kit at once and feeling kind of swamped.
