denon 1906 sub out help
Discussion in 'AV Receivers & Amplifiers' started by Baron Von Doom, Mar 13, 2006.
Tags:
  1. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,563
    worthing
    +176
    ive just replaced my yamaha amp with a 1906.
    ive used the auto setup but cant get any sound out of the sub. it works on the test tone but with any inputs nothing comes out.
    any ideas?
  2. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,563
    worthing
    +176
  3. Timh
    Timh
    Sep 14, 2000
    5,277
    4
    3
    Altair-4
    +343
    go into the speaker setup and make sure you have the sub sellected as yes.
    I think the options are yes, no and sub and mains.
    The auto setup should have sellected the correct option.
  4. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,563
    worthing
    +176
    just got yes and no. it is set to yes
  5. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,563
    worthing
    +176
    it had set the level way to low. turned it up and it now works fine.
    thanks for the help
  6. Timh
    Timh
    Sep 14, 2000
    5,277
    4
    3
    Altair-4
    +343
    :clap:
