Denon 1906 & Panasonic TH42PE50CAB
Discussion in 'AV Receivers & Amplifiers' started by HankQuinlan, Mar 24, 2006.
Tags:
  1. HankQuinlan
    HankQuinlan
    Feb 10, 2006
    4
    Can anyone tell me if the Denon 1906 will safely fit on the shelf of the Panasonic
    TH42PE50CAB?
    the 1906 height is 147 mm (from Denon website) - which might just fit - but what about possible ventilation issues etc...
    Anybody out there got both ? and if so, how have you set them up?
    sorry if this has been asked before...I did a search and could find anything
  2. culp
    culp
    i have 37pe50 the shelfs are 150mm bottom 2 top 1 about 140 but you can move shelfs around on this model so you should be able to fit a drenon on the bottom and say a narrow dvd on centre ie 100mm hope this makes sense.
    culp
