Denon 1906 - exact height??
Discussion in 'AV Receivers & Amplifiers' started by johnrevill, Oct 22, 2005.
Tags:
  1. johnrevill
    johnrevill
    Jul 28, 2004
    128
    +3
    I'm looking at getting one of these but I need to check whether it will fit in the space I've got in my TV unit.
    The 1906 is listed ias being 147mm tall on the Denon website but I want to know if this includes the round feet as I guess they would quite an extra bit of height. The space I've got is approx 157mm so I've not got much room to play with..!
    Would any 1906 owners mind measuring the height of the unit (including the feet)??
    The tight space does throw up concerns about heat build up but the unit will be open on all sides (just not much vertical space).
    cheers.
  2. Radg
    Radg
    Jan 28, 2005
    34
    Hi there
    Not sure about if the feet are included in the height. Would it not be a fairly simple task to just remove the feet? :eek:
  3. machinehead
    machinehead
    Sep 5, 2004
    468
    Greenock
    +15
    the feet are there for an important purpose to create a breathing space between amp and the ground.it's really not advisable to do this.you would be better emailing denon and asking them direct.
  4. Bogeyed
    Bogeyed
    Nov 12, 2004
    79
    Holmfirth,West Yorkshire
    Its 147mm including the feet,but it runs fairly warm so I would ensure plenty of ventilation all round.
  5. johnrevill
    johnrevill
    Jul 28, 2004
    128
    +3
    <b>Bogeyed </b> - have you actually measured it?
    I had thought about the possibility of removing the feet but had presumed they would permanently attached...
  6. Weidass
    Weidass
    Jan 5, 2005
    104
    Cambridgeshire
    if the space you are going to put the amp in is that tight, you will effectively melt the internals of the amp.
    These things are designed to be ventilated, not closed in.
  7. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    it sounds like you need to buy a very slimline amp so it will fit with some ventilation, or if not buy and amp that is designed to work without needing ventilation (usually means it isnt very powerful...lol)
  8. johnrevill
    johnrevill
    Jul 28, 2004
    128
    +3
    Hmm - like I said the amp is open on all other sides so will vertical clearance really be that much of an issue?
  9. Nemeliza
    Nemeliza
    Jul 27, 2005
    58
    Yes......heat is notorious for rising.
  10. Bogeyed
    Bogeyed
    Nov 12, 2004
    79
    Yes-I did measure it,you seem to be a bit tight above the unit,much less than I would have thought desirable-as mentioned earlier I would not remove the feet,they are there to maintain ventilation around the unit.
  11. johnrevill
    johnrevill
    Jul 28, 2004
    128
    +3
    Cheers for confirming bogeyed.
    Nemeliza - no need to be so flippant. I was asking a genuine question.
  12. Nemeliza
    Nemeliza
    Jul 27, 2005
    58
    I was expressing the need for vertical clearance in a way that i thought was 'harmless' but clear.
    Offending you was not my aim and i apologise if thats the message i communicated to you.
  13. johnrevill
    johnrevill
    Jul 28, 2004
    128
    +3
    No worries mate - no offence taken.
