Denon 1906 error message on Auto set-up
SanPedro
I get thsi error when trying to run the auto set-up
Caution FL Sp (thinks that's what it said from memory)
Couldn't find this in the manual's error list.
It plays just fine and all the channels are present.
Any ideas?
Jase
It should have something listing the error like - Phase, None etc.
SanPedro
That's what I thought. But I can't seem to see anything. I'm right in thinking that all the messages are viewable on the amps display, rather than on my screen? I can't seem to get any messages to display on the screen.
The amp is feeding the signal ok from the DVD player to the screen
Jase
Always used the OSD on the Denon's myself. I'd just doublecheck speaker connections to make sure that everythings ok (no loose wires). If it is and everything plays ok I wouldn't worry too much to be honest.
liampurcell
on screen display is only by S-video or composite, not by conponenet if you have your tv connected to your amp that way?
beavertron
really? on the back it has "monitor" next to the s-video/composite video connection but also it has "monitor" next to the component video output. I assumed you would get the osd with either... havent tried component though (prefer to connect video straight from dvd player-tv), just s-vid to the connection on front of my tv. anyone confirm you cant see the osd on 1906 via components?
S
Spoodle
Yep, I can confirm it. Damn nuisance when my only connection is on the front panel of my TV!
Spoodle
SanPedro
Jase
Homer Simpson here. I'd put my front speakers into B rather than A. Doh!
The auto set-up worked a treat once I'd switched 'em around.
I guess it must be a Japanese thing as the 1st set of speaker inputs is marked B and the next set is marked A. I guess it makes sense if you read right to left. Or if you take a bit more time to read the decals on the back. :suicide:
Jase
Easy mistake to make. :)
