Denon 1905 or Yammy 657?
Discussion in 'AV Receivers & Amplifiers' started by tutu, Jun 22, 2005.
Tags:
  1. tutu
    tutu
    Apr 28, 2004
    2,223
    48
    +58
    I have ordered the Canton CD1 set and now I need an amp!.
    The usual equipment:
    Panasonic DMRES30V DVD/VCR (Component & Optical)
    Xbox (Component & Optical)
    PC (Optical)
    Directly to Plasma TV:
    PC => TV (VGA)
    Sky Digital (RGB Scart)
    I would very much like to remove my old hi-fi from my room so the amp will be used for Music, Movies and Games.
    I would like the 3 components on the Denon (1 for expandability - Yammy has 2) but I would also like the av sync on the Yammy - but I have been told that av sync is not really an issue (as with Sky it is intermittent?).
    Also, can the Yammy upconvert a SD feed (component) to a hd feed (720p?)
    Which one is better for music?
    Yammy is £300, Denon is £240
    Any help is greatly appreciated!
  2. tutu
    tutu
    Apr 28, 2004
    2,223
    48
    +58
    I have purchased the Cambridge Azur 540R instead :D It's height is more suitable to the PV500 stand!
  3. systemsdead
    systemsdead
    Jan 19, 2005
    10,542
    grimsby,canada
    +4,453
  4. tutu
    tutu
    Apr 28, 2004
    2,223
    48
    +58
    I've gone for the Yammy 657 now - mainly because of the audio delay feature!
