Denon 1804 - standby without remote?
Discussion in 'AV Receivers & Amplifiers' started by balders, Jan 20, 2004.
Tags:
  1. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    Unless I'm being really dim, I can't find any way of putting my Denon 1804 into/ out of standby without using the remote.
    I've tried all the buttons on the front of the amp, but none will bring it out of standby! Am I missing something?
    (This isn't normally a problem, it's just that the other day I put a DVD in the player and then wanted to set the input on the amp - trouble was it was on standby, so I had to hunt round for the remote).
    Cheers,
    Balders.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I've got the same on my 1802. If you physically turn it off, then back on again using the front main power switch it should default to on and thus be out of standby.
