Denon 1803 RGB+comp switching
Discussion in 'AV Receivers & Amplifiers' started by Darren Blake, May 18, 2003.
Tags:
  1. Darren Blake
    Darren Blake
    Apr 28, 2003
    621
    Norwich, UK.
    +15
    I have just seen the HItachi 42PMA400 at Nexnix being fed a switched 3xphono RGB + 1xphono composite sync signal from a Denon 3802.
    I am assuming to do this you feed the RGB and the composite signals from each source into the Denon also composite + RGB out to the screen, and it sort of "gangs together" the composite and RGB inputs when you switch sources. Probably not a very good description but hopefully you get my drift.
    Can anyone tell me if the 1803 can do this too because I can't afford an 3802 / 3803!
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    No it can't
  3. Darren Blake
    Darren Blake
    Apr 28, 2003
    621
    Norwich, UK.
    +15
    Short & sweet :D
    Cheers for the reply.
