Denon 1803 remote problem
Discussion in 'AV Receivers & Amplifiers' started by mkeene61, Aug 29, 2003.
  1. mkeene61
    Has anyone got this remote to work with any of their other hardware. I have tried to set up the remote so that I can use my philips DVD Player (634 which apparantly is the same as the 640).
    I have followed the instructions and the remote seems to work for one key press eg. the first key I press works- menu brings up the menu, stop stops the disc. But then the remote stops working on the second button press. It's as if it has forgotten the programmed code a split second later.
    Is anyone else having the same problem? Im I doing something wrong?
    Cheers in advance!
