Denon 1710 vs Marantz DV4500
Discussion in 'Blu-ray & DVD Players & Recorders' started by digitaldave, Jun 21, 2005.
  1. digitaldave
    digitaldave
    Jan 7, 2003
    261
    St Evenage
    +12
    I'm still looking at getting a DVD player to replace my Toshiba SD-330E, and was looking at the Denon 1710 and Marantz DV4500. What are the differences between these two models, if any? Is the Marantz worth the extra £100 over the Denon? Output will be via RGB SCART to a Sony 32" TV.
  2. cabstar
    cabstar
    Mar 28, 2005
    1,091
    38
    Grimsby
    +11
    Having had both the Tosh 330e & the Denon 1710 I would say keep the Tosh. I could see hardly any difference between the 2. The Tosh has the edge I think as the build quality feels better than the Denon. I have played both of them through component out to a 42inch RPTV Tosh.
    I certainly havent noticed much difference in the sound quality either.
    Regards
    Gary
  3. digitaldave
    digitaldave
    Jan 7, 2003
    261
    St Evenage
    +12
    cabstar,
    Thanks for the reply :). I'd love to keep the Tosh, as it's a great player, but unfortunately, the mechanism has started making a noise during playback that gets very distracting during quiet scenes :(. So unless I can sort it out somehow, I'm going to need a replacement. I guess I can strike the Denon 1710 off the list.
    Any thoughts about the Denon 1910? Is that a significant step up from the 1710, or does it just add DVI and Faroudja DCDI, both of which would be of no use to me as I don't have a display with DVI input or progressive scan capability :).
    Thanks.
  4. digitaldave
    digitaldave
    Jan 7, 2003
    261
    St Evenage
    +12
    Isn't this just typical... I watched a documentary on the Apollo 13 2 disc se last night, and... no noise :smashin:. Maybe because I have moved things around a bit, so it might have been sitting badly before, or had the chassis slightly twisted? Anyway, happy now, as it's back to being quiet again. That's saved a few quid :).
